Helmet front mount for Muvi and Muvi HD
Veho VCC-A018-HFM Face Pointing Helmet Mount for MUVI HD with 3m Base and MUVI HD Holder
- 3M Mountining point for all sized helmets
- Face pointing arm for filming back at your face from helmet
- Ships with MUVI HD holding mount
- Also compatible with MUVI Micro and MUVI Atom (Needs associated handlebar mount)
The MUVI HD helmet front mount is designed for easy and secure fitting so you can capture all of the action of you. The mount comes with the holder for the MUVI HD and 3M mounting base. It is also compatible with the MUVI Micro and MUVI Atom in conjunction with their own handlebar mounts.
Box Contains
Front Helmet Mount Arm
MUVI HD Holder
3M base
Product Description | Veho Helmet front mount support system - adhesive mount | Product Type | Support system - adhesive mount | Designed For | Muvi Atom, HD |
General | |
Product Type | Support system |
Tripod | |
Supported Devices | Camcorder |
Support Type | Adhesive mount |
Kit Content | |
Kit Content | (1) x helmet mount , (1) x camera holder , (1) x adhesive mounting base |
Compatibility Information | |
Designed For | Veho muvi Atom, HD |
