See everything up close with this amazing USB Microscope. Up to 200x zoom and the ability to take a photo and video of the subject.
This handy USB desktop microscope - 200x, 1.3 Mega Pixels magnification - has a multiude of home and office uses: science education, laboratory research, computer parts examination, printing inspection, presentation tool, medical analysis, reading aid and collectables magnification to name a few. Online chat can also be achieved with the microscope's built in webcam and record features.
Main Features:
- Adjustable LEDs for object illumination
- 1.3 Megapixel lens
- Measurement function using enclosed software
- Snapshot and video recording function
- Alloy stand and stand alone capture button
- Tacton rubber touch housing
- With a base zoom level of 20x, the VMS-001 can be further zoomed in manually to a factor of 200x
- Fine slider adjustment for brightness, hue, saturation and sharpness, plus a black and white display mode
- VMS-001 USB Microscope is supplied with Windows and Mac drivers. For software for side-loading CD drives just visit the download centre
- The 1.3 megapixel CMOS lens can be adjusted to point in any direction using the movable arm
- Simply install the drivers, plug the microscope into your computer via the USB and you''re ready to go
Contents:
- Microscope
- User Guide
- Software CD
Product Description | Veho VMS-001 USB Microscope - microscope | Device Type | Microscope | Connectivity Technology | Wired | Camera | Colour | Optical Zoom | 200 x | Max Resolution | 1280 x 960 | Optical Sensor Type | CMOS 1.3 MP | Focus Adjustment | (min distance 1 cm) | Interfaces | USB 2.0 | Features | USB powered, built-in LED illuminator |
General | |
Camera | |
Type | Colour |
Max Digital Video Resolution | 1280 x 960 |
Image Sensor | |
Type | 1.3 MP CMOS |
Lens Construction | |
Min Focus Distance | 1 cm |
Interfaces | |
Computer Interface | USB 2.0 |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 |
Miscellaneous | |
Compliant Standards | RoHS |
Software / System Requirements | |
OS Required | Microsoft Windows 98/2000/XP, Apple MacOS X 10.5 or later, Microsoft Windows Vista (32/64 bits) |
