With USB ports in almost every computer and popping up in cars, DVD and multimedia players, TVs, photo frames and more, USB drives are now being considered an essential accessory.
The Store 'n' Go PinStripe USB drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
This USB flash drive comes in paper blister package.
Product Description | Verbatim PinStripe USB Drive - USB flash drive - 32 GB | Product Type | USB flash drive | Interface Type | USB 2.0 | Storage Capacity | 32 GB | Enclosure Colour | Black | OS Required | Apple MacOS X 10.1 or later, Linux Kernel 2.6 or later, Microsoft Windows 7 or later | Microsoft Certification | Certified for Windows Vista | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Features | Retractable connector, Push & Pull Mechanism |
Miscellaneous | |
Certified for Windows Vista | Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security. |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Dimensions & Weight | |
Width | 52.3 mm |
Depth | 19.1 mm |
Height | 7.9 mm |
Weight | 10 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 88.9 mm |
Shipping Depth | 9.7 mm |
Shipping Height | 134.9 mm |
Shipping Weight | 20 g |
