Info
The wide range of available colors and translucencies and glossy feel often attract those who print for display or small household uses. Many appreciate the plant based origins and prefer the semi-sweet smell over ABS. When properly cooled, PLA seems to have higher maximum printing speeds, lower layer heights, and sharper printed corners. Combining this with low warping on parts make it a popular plastic for home printers, hobbyists, and schools.
Biodegradable, corn-based plastic. Prints at ~180-230 °C, and doesn't warp, so you can print big things without a heated bed.
Why PLA?
Tips
The printing temperature guideline for printing with our PLA filament is approximately 210°C. As each desktop 3D printer has its own unique characteristics, you might need to tweak around with your temperature settings a bit to get the best results. To obtain optimal results for your prints you need to take into account variables like your 3D printer's nozzle diameter, your printing speed settings, and layer height.
PLA has much less tendency to warp compared to ABS. Therefore it can be printed both with and without a heated print bed. However, if your desktop 3D printer does have a heated print bed it is recommended to set your print bed temperature to approximately 40° to 50° C.
A good first layer adhesion is of the utmost importance in obtaining the best results for your prints. There are several tricks to get the first layer of your PLA print to stick better to the print bed of your 3D printer.
Blue Masking Tape. PLA prints usually stick really well to blue masking tape. When preparing the print bed it is better to have tiny gaps between your strokes of masking tape, rather than having overlaps.
Overlaps of smaller pieces of tape may cause difficulties later on during the print process. We have tested a wide variety of masking tapes and found that the best results can be obtained with Eurocel Blue Masking Tape.
Coat your print bed with hairspray. Like ABS, PLA has a tendency to stick really well to extra strong hairsprays.
Blue masking tape is unlikely to leave a residue on your print bed. A hairspray coating however will leave a residue on your print bed.
Product Description | Verbatim - blue - PLA filament | Product Type | PLA filament | Filament Diameter | 1.75 mm | Weight | 1 kg | Printing Technology | FDM | Printing Colour | Blue | Image Colour Disclaimer | The displayed product image may be a different colour | Manufacturer Warranty | 2-year warranty |
Consumable | |
Consumable Type | PLA filament |
Weight | 1 kg |
Colour | Blue |
Nozzle Temperature | 220 °C |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | 2-year warranty |
