Laying the foundation for a worry-free data center, HGST delivers capacity to conquer the data explosion - Ultrastar He12 HDD. Designed to handle workloads up to 550TB per year, the Ultrastar He12 HDD is the industry's first 12TB drive and uses PMR technology to make it drop-in ready for any enterprise-capacity application or environment. The stable internal environment created by fourth-generation HelioSeal technology enables a new 8-disk design, increasing the capacity by 20% when compared to the 7-disk design of the prior generation. This highest capacity helium drive offers the lowest power profile in the industry to help data center architects meet eco-environmental goals and requirements. Targeted at 2.5M hours MTBF, the Ultrastar He12 HDD provides the highest reliability rating available of all HDDs on the market today by building on the successful design of its 10TB, 8TB and 6TB predecessors. Trust HGST and the Ultrastar He12 HDD to deliver more capacity, more efficiency, more reliability and more value to your data center.
Product Description | WD Ultrastar DC HC520 HUH721212ALE604 - hard drive - 12 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 12 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | Dual Stage Actuator (DSA), Secure Erase function, HelioSeal, 24x7 continuous operation, Enhanced Rotational Vibration Safeguard (RVS), advanced format 512e, Dynamic fly height technology | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 660 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 12 TB |
Bytes per Sector | 512 |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 660 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 255 MBps |
Seek Time | 8 ms (average) / 8.6 ms (max) |
Average Latency | 4.16 ms |
Reliability | |
MTBF | 2,500,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^15 |
Load / Unload Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 6.9 Watt (active) , 5 Watt (idle) |
Miscellaneous | |
Compliant Standards | RoHS 2011/65/EU |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 70 g @ 2 ms half-sine wave |
Shock Tolerance (non-operating) | 300 g @ 2 ms half-sine wave |
Vibration Tolerance (operating) | 0.67 g @ 5-500 Hz |
Vibration Tolerance (non-operating) | 1.04 g @ 2-200 Hz |
