With sequential read speeds up to 2050MB/s, the WD Black PCIe Gen3 x4 NVMe-based SSD unlocks a new level of performance for high-performance PC users.
Product Description | WD Black NVMe SSD WDS100T2X0C - SSD - 1 TB - PCIe 3.0 x4 (NVMe) | Type | Solid state drive - internal | Capacity | 1 TB | Form Factor | M.2 2280 | Interface | PCIe 3.0 x4 (NVMe) | Features | 3D NAND Technology, Western Digital Spectrum | Dimensions (WxDxH) | 80 mm x 2.38 mm x 22 mm | Weight | 7.5 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 1 TB |
Width | 80 mm |
Depth | 2.38 mm |
Height | 22 mm |
Weight | 7.5 g |
Performance | |
SSD Endurance | 600 TB |
Internal Data Rate | 3400 MBps (read) / 2800 MBps (write) |
4KB Random Read | 500000 IOPS |
4KB Random Write | 400000 IOPS |
Reliability | |
MTBF | 1,752,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x PCI Express 3.0 x4 (NVMe) |
Compatible Bay | M.2 2280 |
Power | |
Power Consumption | 140 mW (active) |
Software & System Requirements | |
Software Included | Acronis True Image WD Edition, WD SSD Dashboard |
Miscellaneous | |
Compliant Standards | UL, TUV, VCCI, C-Tick, BSMI, FCC, KCC |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Min Storage Temperature | -55 °C |
Max Storage Temperature | 85 °C |
Vibration Tolerance (operating) | 5 g @ 10-2000 Hz |
Vibration Tolerance (non-operating) | 4.9 g @ 7-800 Hz |
