We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
A SATA III Internal SSD is Ideal for Any NAS Array
The WD Red™ SA500 NAS SATA SSD is an ideal choice for NAS arrays that operate in an always-on, 24/7 environment. Specifically designed and tested for the harsh conditions of a NAS array, WD Red SSDs feature advanced caching to handle even the most demanding applications.
Fast, Reliable SATA III Storage
A WD Red™ SA500 NAS SATA SSD can enhance your NAS’s response time. Efficient caching of big files makes the WD Red SSD ideal for OLTP databases, multi-user environments, photo rendering, 4k and 8k video editing and more.
Blazing-Fast File Access
WD Red SSDs are optimized for fast file access and can cache your most frequently used data for even faster access.
The Endurance of SSD
Because WD Red SSDs have no moving parts, there’s less to wear out over time – heat and vibration are reduced as well.
Work Faster and Save Time
Western Digital® 3D NAND, the WD Red™ SSD delivers outstanding SATA III performance to accelerate your productivity and save you time.
Intense Apps are No Problem
HD Video, 4K and 8K formats require a fast drive that reduces latency for hassle-free editing and transfer of huge multimedia files.
Product Description | WD Red SA500 WDS200T1R0B - SSD - 2 TB - SATA 6Gb/s | Type | Solid state drive - internal | Capacity | 2 TB | Form Factor | M.2 2280 | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Features | 24x7 continuous operation, 3D NAND Technology | Dimensions (WxDxH) | 22 mm x 80 mm x 2.38 mm | Weight | 7 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 2 TB |
Width | 22 mm |
Depth | 80 mm |
Height | 2.38 mm |
Weight | 7 g |
Performance | |
SSD Endurance | 1300 TB |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 560 MBps (read) / 530 MBps (write) |
4KB Random Read | 95000 IOPS |
4KB Random Write | 85000 IOPS |
Reliability | |
MTBF | 2,000,000 hours |
24x7 Operation | Yes |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - M.2 Card |
Compatible Bay | M.2 2280 |
Power | |
Power Consumption | 60 mW (active) , 3000 mW (read) , 3800 mW (write) , 56 mW (sleep) , 12 mW (DevSleep) |
Miscellaneous | |
Compliant Standards | UL, TUV, VCCI, BSMI, FCC, KC, Morocco |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Min Storage Temperature | -55 °C |
Max Storage Temperature | 85 °C |
Shock Tolerance (non-operating) | 1500 g @ 0.5 ms half-sine |
Vibration Tolerance (operating) | 5 g @ 10-2000 Hz |
Vibration Tolerance (non-operating) | 4.9 g @ 7-800 Hz |
