The My Book desktop hard drive is designed to complement your personal style with a massive amount of space to store your photos, videos, music and documents.
Complete Backup, Time Machine-Compatible
Equipped with WD Backup software for Windows and Apple Time Machine compatibility for Mac, the My Book desktop hard drive can back up your photos, videos, music and documents. The My Book desktop hard drive also works great with Acronis True Image WD Edition software to schedule full system backups.
Password Protection with Hardware Encryption
With built-in 256-bit AES hardware encryption with WD Security software, you can set your own personalized password to help keep your content private and safe.
Easy to Use
Ready to use out of the box, start transferring files, saving memories and backing up. WD Backup and WD Security software are included to help protect your data. The My Book drive is also compatible with Apple Time Machine.
Reimagined Design
The compact design of the My Book drive exudes a confidence reflective of its reliability. With up to 8TB of storage capacity, you can trust your My Book drive to be the home of your digital life.
Massive Capacity
With up to 8TB of capacity, there's plenty of room to save the massive amounts of photos, videos, and music you love, plus your important documents.
WD Quality Inside and Out
Millions of people around the world trust their data to the My Book desktop hard drive. Designed to meet WD's demanding requirements for durability, shock tolerance and long-term reliability, we stand by the trusted My Book desktop storage with a 2-year limited warranty
Product Description | WD My Book WDBBGB0030HBK - hard drive - 3 TB - USB 3.0 | Type | Hard drive - external (desktop) | Capacity | 3 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) | Features | Password authentication, hardware encryption, automatic backup, exFAT formatted | Power Source | Included AC adapter | Enclosure Colour | Black | Dimensions (WxDxH) | 49 mm x 139.3 mm x 170.6 mm | Weight | 960 g | Localisation | EMEA | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 3 TB |
Width | 49 mm |
Depth | 139.3 mm |
Height | 170.6 mm |
Weight | 960 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software & System Requirements | |
Software Included | Backup Software, WD Security, WD Drive Utilities |
OS Required | Windows 10 or later, Apple macOS 11 or later |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable - external |
Compliant Standards | Directive 2002/95/EC, NRCAN |
Package Type | Retail |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 65 °C |
