WD 4TB Elements USB 3.0 3.5" Desktop Hard Drive
£111.19
26 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Hi-Speed USB 2.0, backward compatible with USB 1.1 ports
  • Plug and Play storage
  • Rugged metal case
  • Simple add-on storage
  • Form Factor: 3.5
  • Capacity: 4TB, >3TB-5TB
  • Interface: SuperSpeed USB, USB
Product codes
chevron icon
chevron icon
WD Elements USB 3.0 external hard drive is an easy-to-use, reliable way to add more storage to your PC or Macintosh. Simply plug it in to a USB port and start saving or backing up your photos, music, video, and files. It's preformatted for immediate use so there's no software or CD to load. The compact, durable metal case provides extra data protection helping keep data safe from loss.
chevron icon
Product Description WD Elements Desktop WDBWLG0040HBK - hard drive - 4 TB - USB 3.0
Type Hard drive - external (desktop)
Capacity 4 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features NTFS formatted
Power Source Included AC adapter
Dimensions (WxDxH) 48 mm x 135 mm x 165.8 mm
Weight 950 g
Localisation United Kingdom
Microsoft Certification Compatible with Windows 7
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£111.19
