We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
WD's exclusive NASware technology, built into every WD Red hard drive, improves NAS storage performance by reducing common hard drive concerns in NAS systems including concerns for things like compatibility, integration, upgradeability, reliability and cost of ownership that are experienced with a hard drive designed for desktop computers.
Product Description | WD Red WD40EFAX - hard drive - 4 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 4 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 5400 rpm | Features | Native Command Queuing (NCQ), Advanced Format technology, NAS compatible, NASware technology, 24x7 availability | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 570 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 4 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 570 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 150 MBps |
Reliability | |
MTBF | 1,000,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 4.5 Watt (read) , 4.5 Watt (write) , 3.3 Watt (idle) , 0.4 Watt (sleep) , 0.4 Watt (standby) |
Miscellaneous | |
Compliant Standards | RoHS 2011/65/EU |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 65 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 30 g @ 2 ms |
Shock Tolerance (non-operating) | 250 g @ 2 ms |
