The My Passport SSD is portable storage with blazing-fast transfers. Password protection with hardware encryption helps keep your content secure. Easy to use, the My Passport SSD is shock-resistant, compact storage in a cool, durable design.
Product Description | WD My Passport SSD WDBKVX5120PSL - SSD - 512 GB - USB 3.1 Gen 2 | Type | Solid state drive - external (portable) | Capacity | 512 GB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | Interface | USB 3.1 Gen 2 - USB-C | Data Transfer Rate | 10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) | Features | Shock resistant, password authentication, automatic backup, Apple Time Machine compatible | Power Source | USB bus | Enclosure Colour | Black top with gunmetal (medium metallic grey) bottom | Dimensions (WxDxH) | 45 mm x 90 mm x 10 mm | Localisation | Worldwide (excluding China) | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - external (portable) |
Capacity | 512 GB |
Interface | USB 3.1 Gen 2 |
Width | 45 mm |
Depth | 90 mm |
Height | 10 mm |
Performance | |
Interface Transfer Rate | 10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) |
Max Data Transfer Rate | 540 MB/s |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.1 Gen 2 - 24 pin USB-C |
Power | |
Software & System Requirements | |
Software Included | WD Security, WD Drive Utilities, WD Backup, WD Discovery |
OS Required | Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS Sierra 10.12 |
Miscellaneous | |
Cables Included | 1 x USB-C cable , 1 x USB-C to USB-A adapter |
Compliant Standards | Directive 2002/95/EC |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 65 °C |
