The My Passport portable drive is trusted to store the massive amounts of photos, videos and music you love. Available in an array of vibrant, fun colors, the sleek style fits comfortably in the palm of your hand, so you can easily take your treasured content everywhere you go.
Product Description | WD My Passport SSD WDBK3E5120PSL - SSD - 512 GB - USB 3.1 Gen 2 | Type | Solid state drive - external (portable) | Capacity | 512 GB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | Interface | USB 3.1 Gen 2 - USB-C | Data Transfer Rate | 10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) | Features | Shock resistant, password authentication, automatic backup | Power Source | USB bus | Enclosure Colour | Black top with gunmetal (medium metallic grey) bottom | Dimensions (WxDxH) | 45 mm x 90 mm x 10 mm | Localisation | Worldwide (excluding China) | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - external (portable) |
Capacity | 512 GB |
Interface | USB 3.1 Gen 2 |
Width | 45 mm |
Depth | 90 mm |
Height | 10 mm |
Performance | |
Interface Transfer Rate | 10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) |
Max Data Transfer Rate | 515 MB/s |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.1 Gen 2 - 24 pin USB-C |
Power | |
Software & System Requirements | |
Software Included | WD Security, WD Drive Utilities, WD Backup, WD Discovery |
OS Required | Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS Sierra 10.12 |
Miscellaneous | |
Cables Included | 1 x USB-C cable , 1 x USB-C to USB-A adapter |
Compliant Standards | Directive 2002/95/EC |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 65 °C |
