WD Elements desktop storage with USB 3.0 offers reliable, add-on storage, ultrafast data transfer rates and universal connectivity with USB 3.0 and USB 2.0 devices. The sleek design features generous capacity, renowned WD quality.
Product Description | WD Elements Desktop WDBWLG0060HBK - hard drive - 6 TB - USB 3.0 | Type | Hard drive - external (desktop) | Capacity | 6 TB | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Power Source | Included AC adapter | Enclosure Colour | Black | Dimensions (WxDxH) | 48 mm x 135 mm x 165.8 mm | Localisation | EMEA |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 6 TB |
Width | 48 mm |
Depth | 135 mm |
Height | 165.8 mm |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software & System Requirements | |
Software Included | WD SmartWare Pro (30 days trial) |
OS Required | Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8 |
Miscellaneous | |
Cables Included | 1 x USB cable - external |
Compliant Standards | RoHS |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 65 °C |
