The My Passport Ultra drive is trusted, portable storage in a design that has a sophisticated style. With plenty of space to store all the content you love, it will help keep all your memories safe and secure. Easy to use, just plug it in to start saving and backing up.
Product Description | WD My Passport Ultra WDBTLG0020BGY - hard drive - 2 TB - USB 3.0 | Type | Hard drive - external (portable) | Capacity | 2 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) | Features | Password authentication, automatic backup, cloud backup | Power Source | USB bus | Enclosure Colour | Grey, black | Dimensions (WxDxH) | 81.5 mm x 110 mm x 13.5 mm | Weight | 140 g | Localisation | Worldwide (excluding China) | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - external (portable) |
Capacity | 2 TB |
Width | 81.5 mm |
Depth | 110 mm |
Height | 13.5 mm |
Weight | 140 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Software & System Requirements | |
Software Included | WD Security, WD Drive Utilities, WD Backup, WD Discovery |
OS Required | Microsoft Windows 7 / 8.1 / 10 |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable - external |
Compliant Standards | Directive 2002/95/EC |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 65 °C |
Humidity Range Operating | 20 - 80% |
