ITEM | QTY | PRICE |
Seagate Xbox series S/X 4TB Gaming Dr...
2 | £283.24 |
Dell P2723QE 27" 3840x2160 5ms H...
4 | £1,644.08 |
StarTech.com 1m Blue Cat6a Cable STP
4 | £46.48 |
Say hello to more for your Xbox. As game files get larger, the WD BLACK C50 Expansion Card for Xbox is the fast and easy way to give your Xbox Series X|S a big capacity boost and keep more titles installed. Just plug this officially licensed card directly into the console for similar performance as the Xbox internal storage.
Product Description | WD Black C50 Expansion Card for XBOX - hard drive - 512 GB | Type | Hard drive - external (portable) | Capacity | 512 GB | Features | Xbox compatible | Dimensions (WxDxH) | 31.6 mm x 55.6 mm x 7.7 mm | Weight | 25 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - external (portable) |
Capacity | 512 GB |
Width | 31.6 mm |
Depth | 55.6 mm |
Height | 7.7 mm |
Weight | 25 g |
Software & System Requirements | |
Software Included | Xbox Game Pass Ultimate (1 month) |
OS Required | Xbox One S system software, Xbox One X system software |
Miscellaneous | |
Included Accessories | Protective cover |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years , Money back guarantee - 30 days |
Environmental Parameters | |
Min Operating Temperature | -5 °C |
Max Operating Temperature | 55 °C |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 85 °C |
