Meet Echo
All the benefits of Alexa, now with improved sound and a new look. Enjoy premium speakers with equaliser controls, and easily set up multiple compatible devices for stereo sound or multi-room music.
"Alexa, play top hits."
Use your voice to play a song, artist or genre through Amazon Music, Apple Music, Spotify, Deezer and TuneIn. With compatible Echo devices in different rooms, you can fill your entire home with music as well as listen to Audible or radio stations
Alexa is happy to help
Make your life easier at home. Use your voice to set timers, add items to lists and create calendar events and reminders. You can also check the news, weather or traffic. Ask for sports scores, film screening times or information.
Voice control your smart home
Manage compatible smart home devices using your voice. Switch on the lamp before getting out of bed, turn on the coffee machine on your way to the kitchen, or dim the lights from the sofa to watch a film.
Connect with your friends and family
Make hands-free calls to almost anyone including UK mobile and residential numbers (from UK only, emergency calling not supported), other Echo devices and the Alexa app. You can also link Alexa with your UK EE and Vodafone UK mobile phone account to ask Alexa to make and answer your mobile calls. Use Announcements to send voice messages to every room with an Echo device, or use Drop In as a two-way intercom between rooms.
Alexa has skills
With tens of thousands of skills and counting, Alexa is always getting smarter. Skills are like apps and help you do more, such as play relaxing sounds or test your music knowledge. Just say, "Alexa, what are your top skills?"
Designed to protect your privacy
Alexa and Echo devices are built with multiple layers of privacy protection. For example, Echo has a Microphone Off button that electronically disconnects the microphones. You also have control over your voice recordings You can view hear or delete them at any time Amazon
Product Description | Amazon Echo (3rd Generation) - smart speaker | Product Type | Smart speaker | Localisation | United Kingdom | Speaker Type | 2-way - active | Interfaces | Bluetooth, Wi-Fi | Intelligent Assistant | Alexa - direct | Streaming Services | Deezer, Spotify, TuneIn, Apple Music, Amazon Music, Audible | Speaker Details | Speaker - mono - 2-way - active | Colour | Charcoal | Dimensions (WxDxH) | 9.9 cm x 9.9 cm x 14.8 cm | Weight | 780 g | Manufacturer Warranty | 1-year warranty |
General | |
Features | 360° omni-directional |
Hands-Free Function | Yes |
Microphone | Yes |
Enclosure Colour | Charcoal |
Speaker System | |
Amplifier | Integrated |
Interfaces | Bluetooth, IEEE 802.11a/b/g/n/ac |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Internet Streaming Services | Deezer, Spotify, TuneIn, Apple Music, Amazon Music, Audible |
Controls | Volume, mute microphone, action |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Communications Type | Cloud |
Intelligent Assistant | Alexa |
Voice Control | Direct |
Speaker System Details | |
Driver Details | Woofer driver - 3" , Tweeter driver - 0.8" |
Connections | |
Connector Type | Audio line-in / audio line-out (mini-phone stereo 3.5 mm) |
Power | |
Power Source | AC power adapter |
Dimensions & Weight | |
Width | 9.9 cm |
Depth | 9.9 cm |
Height | 14.8 cm |
Weight | 780 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
