ITEM | QTY | PRICE |
Epson AL-M200/MX200 Standard Capacity...
3 | £262.35 |
We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Completely wireless: Qi certified and packed with more than enough power to charge smartphones, headphones, charging cases and more with up to 10 W power
Hi-speed USB: Simply connect via USB-A or USB-C and charge at a speed of up to 18 W
Power a Full Day
PowerCore is equipped with a 10,000mAh capacity to keep your devices charged for at least a full day. Charge an iPhone 11 or Pixel 4 more than twice, or charge a Galaxy S20 over 1.5 times.
This wireless charger does not feature MagSafe-style magnetic alignment, and therefore is not able to charge the iPhone 13 or 12 series magnetically. The wireless charging feature does not work with the Apple Watch series or Samsung Watch series.
Product Description | Anker PowerCore 10000 wireless power bank - USB - 12 Watt | Product Type | Wireless power bank | Dimensions (WxDxH) | 60 mm x 92 mm x 22 mm | Weight | 180 g | Colour | Black | Output Connector Type | Total 2: USB - on cable: USB-C | Wireless Charging | Yes | Wireless Charging Standards | Qi | Battery | 10000 mAh | Power Provided | 12 Watt | Cables | USB-C to USB-A cable | Manufacturer Warranty | 18 months warranty |
General | |
Designed For | Tablet, mobile phone |
Width | 60 mm |
Depth | 92 mm |
Height | 22 mm |
Weight | 180 g |
Enclosure Colour | Black |
Power Device | |
Input Connectors | 24 pin USB-C |
Input Connectors Qty | 1 |
Output connectors | Total 2: 4 pin USB Type A |
Detachable Cable Connector Type | USB-C |
Battery | |
Capacity | 10000 mAh |
Features | LED power meter |
Miscellaneous | |
Included Accessories | Carrying pouch |
Cables Included | USB-C to USB-A cable |
Compliant Standards | Qi |
Manufacturer Warranty | |
Service & Support | Limited warranty - 18 months |
