These Apple-designed cases fit snugly over the curves of your iPhone without adding bulk. They're made from specially tanned and finished European leather, so the outside feels soft to the touch and develops a natural patina over time. On the inside, a microfiber lining helps protect your iPhone. And the machined aluminum buttons match the finish of your iPhone case.
Product Description | Apple - back cover for mobile phone | Product Type | Back cover for mobile phone | Material | Leather | Colour | Midnight blue | Designed For | Apple iPhone 7 Plus |
General | |
Lining Material | Microfibre |
Carrying Case | |
Type | Protective cover |
Recommended Use | For mobile phone |
Cover Type | Back cover |
Compatibility Information | |
