Designed by Apple to complement your iPhone, the form of the silicone case fits snugly over the volume buttons, side button, and curves of your device without adding bulk. A soft microfiber lining on the inside helps protect your iPhone. On the outside, the silky, soft-touch finish of the silicone exterior feels great in your hand. And you can keep it on all the time, even when you're charging iPhone wirelessly.
Product Description | Apple - back cover for mobile phone | Product Type | Back cover for mobile phone | Material | Silicone | Colour | Midnight blue | Designed For | Apple iPhone 7 Plus |
General | |
Lining Material | Microfibre |
Carrying Case | |
Type | Protective cover |
Recommended Use | For mobile phone |
Cover Type | Back cover |
Compatibility Information | |
