Magic Keyboard with Numeric Keypad features an extended layout, with document navigation controls for quick scrolling and full-size arrow keys for gaming. A scissor mechanism beneath each key allows for increased stability, while optimized key travel and a low profile provide a comfortable and precise typing experience. The numeric keypad is also great for spreadsheets and finance applications. And the built-in, rechargeable battery is incredibly long-lasting, powering your keyboard for about a month or more between charges.
Product Description | Apple Magic Keyboard with Numeric Keypad - keyboard - QWERTY - UK - space grey Input Device | Device Type | Keyboard | Interface | Bluetooth | Localization and Layout | QWERTY UK | Hot Keys Function | Multimedia | Numeric Keypad | Yes | Colour | Space grey | Dimensions (WxDxH) | 41.87 cm x 11.49 cm x 1.09 cm | Weight | 390 g |
General | |
Region | United Kingdom |
Keyboard Technology | Scissors |
Detachable Cable | Yes |
Features | Numeric keypad |
Width | 41.87 cm |
Depth | 11.49 cm |
Height | 1.09 cm |
Weight | 390 g |
Miscellaneous | |
Included Accessories | Lightning to USB cable |
Software & System Requirements | |
OS Required | Apple macOS Sierra 10.12.4, Apple iOS 10.3 or later |
Battery | |
Type | Rechargeable |
