Beats Fit Pro is equipped with comfortable, secure-fit wingtips that flex to fit your ear. The universal wingtip design was put to the ultimate test by athletes of all kinds so you can trust these earbuds will stay put through work days and workouts. Complete with pressure relieving vents, you can comfortably wear these earbuds all day long.
Three soft silicone eartip options make it easy to find the right size. The Fit Test setup for both Apple and Android helps ensure proper fit for a customized acoustic seal and optimal performance.
Product Description | Beats Fit Pro - true wireless earphones with mic | Product Type | True wireless earphones - Bluetooth | Compatibility | iPhone, iPad, iPod, Android phone, Mac, Android tablet | Recommended Use | Portable electronics | Additional Functions | Wireless audio sharing, transparency mode, spatial audio with dynamic head tracking | Colour | Black beats | Headphones Form Factor | In-ear | Wireless Technology | Bluetooth | Sound Output Mode | Stereo | Active Noise Canceling | Yes | Microphone Operation Mode | Beamforming | Controls | Programmable button | Intelligent Assistant | Siri |
General | |
Product Type | True wireless earphones - Bluetooth - wireless |
Dimensions & Weight Details | Charging case: 6.2 cm x 6.2 cm x 2.85 cm / 55.1 g |
Width | 2.4 cm |
Depth | 3 cm |
Height | 1.9 cm |
Weight | 5.6 g |
Protection | Sweat-resistant, IPX4, water-resistant |
Audio Output | |
Connectivity Technology | Wireless |
Active Noise Cancelling Technology | Adaptive Active Noise Cancellation |
Features | Apple H1 chip, Fit Test |
Microphone | |
Form Factor | Built-in |
Remote Control | |
Tracking | |
Sensors | Accelerometer, gyroscope |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Included Accessories | 3 pairs of silicone ear tips, charging case, USB-C to USB-C charging cable |
Cable Details | USB-C to USB-C cable |
Compliant Standards | Bluetooth Class 1 |
Power | |
Battery | Headphone battery rechargeable - Lithium Ion |
Run Time (Up To) | 7 hour(s) |
Run Time Details | Continuous playback (noise cancelling OFF): up to 7 hours , Continuous playback (noise cancelling ON): up to 6 hours , Continuous playback (noise cancelling ON / with included charging case): up to 24 hours |
