Charge and sync your Samsung Galaxy devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Use the MiXiT UP micro USB to USB ChargeSync cable to charge and sync your Samsung at the fastest possible speed. The small, durable micro USB connector also works with most smartphones and tablets with a micro USB port.
The MiXiT UP ChargeSync cable plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
Product Description | Belkin MIXIT - USB cable - Micro-USB Type B to USB - 2 m | Type | USB cable | Features | Sync and charge | Length | 2 m | Connector | 5 pin Micro-USB Type B - male | Connector (Second End) | 4 pin USB Type A - male | Colour | Blue |
General | |
Type | USB cable |
Length | 2 m |
Colour | Blue |
Connectivity | |
