Snap Shield is a fast and simple way to protect MacBooks and Chromebooks in the classroom. A customized fit ensures installation is easy, and requires little set up and maintenance after application. The two-part, slim-fit case offers scratch protection for devices, top and bottom, and works seamlessly with convertible or touchscreen models. Retractable feet on the bottom of the case provide adjustable keyboard angles to make typing easy.
Product Description | Belkin Snap Shield for Acer C720 (11-inch Case) - notebook cover | Product Type | Notebook cover | Colour | Translucent | Product Material | Polycarbonate | Notebook Compatibility | 11" | Features | Scratch-proof, impact resistant, built-in stand | Designed For | Acer Chromebook C720, C720-2103, C720-2420, C720-2800, C720-2802, C720-2832, C720-2844, C720-2848, C720-29552G01aii, C720-29552G03aii, C720-29554G01aii, C720-29554G03aii, C720-29572G01aii, C720-3404, C720-34052G03aii, C720-34054G03aii |
General | |
Compatibility Information | |
