The Belkin USB-C to USB-C cable allows you to charge your USB-C enabled device quickly and safely. Simply plug into any USB-C port to not only charge, but sync and transfer data as well. With a sleek and low profile connector, this cable's minimal design harnesses the incredible power within. Experience 10 Gbps transfer speeds, 20X faster than USB 2.0 (480 Mbps), 12x faster than FireWire 800, and 2X faster than USB 3.0 (5Gbps).
Product Description | Belkin - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m | Type | USB-C cable | Technology | Shielded | Features | 4K support, USB Power Delivery (3A, 60W), sync and charge, 10 Gbps data rate | Length | 1 m | Connector | 24 pin USB-C - male - reversible | Connector (Second End) | 24 pin USB-C - male - reversible | Compliant Standards | USB 3.1 | Colour | Black |
General | |
Shielding Material | Braid |
Jacket Material | Thermoplastic elastomer (TPE) |
Length | 1 m |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB 3.1, USB-IF |
