Now you can attach all your high-speed USB devices to your computer and enjoy error-free transmissions. The Belkin Pro Series Hi-Speed USB 2.0 Cable is the perfect solution for connecting your USB printer, scanner, hard drive, and other equipment. It supports up to 127 devices on a daisy-chain configuration and transmits data at up to 480Mbps. Gold-plated copper contacts provide maximum conductivity and minimize data loss, and hot-pluggable design assures fast connectivity.
Product Description | Belkin PRO Series - USB cable - USB to USB Type B - 1.8 m | Type | USB cable | Technology | Shielded | Features | Molded | Length | 1.8 m | Connector | 4 pin USB Type A - male | Connector (Second End) | 4 pin USB Type B - male | Compliant Standards | USB / USB 2.0 | Manufacturer Warranty | Limited lifetime warranty | Designed For | ExpressBus 7-port, Plus; USB Direct Connect |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 26 |
Plated Connector | Gold |
Features | Molded |
Length | 1.8 m |
Connectivity | |
Miscellaneous | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | Belkin ExpressBus 7-port, Plus , Belkin USB Direct Connect |
