Refurbished stock with full 2 year warranty. Fully tested grade A condition, external packaging may have some minor cosmetic damage.
Internet from the loft to the cellar. And in every room between.
Staying glued to that box set season finale from living room to bath. Video calling your family on the other side of the world. Changing a fuse, with a YouTube tutorial guiding the way beside you. Sifting through boxes of memories in the loft, to the soundtrack of your teens.
Wherever you are in your home, Whole Home Wi-Fi puts what matters most at your fingertips. It brings super-fast, super-reliable Internet to every room. It talks to all your gadgets to make sure they’re always connected to the fastest and strongest signal. And it’s bristling with brilliant controls that put you in charge of a supercharged home network.
No more deadspots.
With Whole Home Wi-Fi you can have your favourite TV, films, music and games in any room you wish. Three brilliant discs create a complete Wi-Fi network – which means no more notspots. Even when there’s a laptop connected in the kitchen, smartphones upstairs and a tablet in the lounge – they all stay connected, all the time.
The technical bit
Whole Home Wi-Fi is an "intelligent self-configuring wireless network". That means it knows where you and your devices are, and when to switch them from one disc to another to give you the strongest and fastest connection it can. The three discs might be small, but their four built-in AC2600 11ac 2.4GHZ and 5GHZ antennas pack a mighty wireless punch.
Keeping you safe
Whole Home Wi-Fi uses the latest security standards to keep your home network safe from outside interference. And one touch updates mean your home is always protected by the latest up-to-the-minute security patches and upgrades.
It just works
With brand new technology, one touch software updates and an app to control it all from, this is Wi-Fi at its simplest. It’s Internet that just works.
You’re in charge
First, the Whole Home Wi-Fi app tells you just where to put each disc for the best connection. Then once everything’s working, it puts you in charge.
Want to see who’s hogging your connection?
You can see who’s online and how much bandwidth they’re using.
Want to get everyone down for dinner? Or just get some time offline?
Pause the internet completely with one tap.
Disc lights too bright for your bedroom?
Turn them down, or off completely.
Technical gremlins?
The app will spot – and explain how to fix – them.
Product Description | BT Whole Home Wi-Fi - Trio - Wi-Fi system - 802.11a/b/g/n/ac - desktop | Device Type | Wi-Fi system | Enclosure Type | Desktop | Wi-Fi System Components | 3 access points | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 1733 Mbps | Remote Management Protocol | HTTP | Features | Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network | Compliant Standards | IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v | Power | AC 230V (50 Hz) | Dimensions (WxDxH) | 16.5 cm x 7.7 cm x 16.5 cm | Weight | 415 g | Manufacturer Warranty | 2-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | AES, TKIP, WPA, WPA2, WPS |
Wi-Fi Rating | AC2500 |
Status Indicators | WPS, starting, connection status |
Line Properties | |
Line Coding Format | 256 QAM |
Expansion / Connectivity | |
Interfaces | WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Power | |
Power Device | External power adapter |
Installed Qty | 2 |
Voltage Required | AC 230V (50 Hz) |
Power Consumption Operational | 7.09 Watt |
Miscellaneous | |
Cables Included | 1 x network cable |
Dimensions & Weight | |
Width | 16.5 cm |
Depth | 7.7 cm |
Height | 16.5 cm |
Weight | 415 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 85% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
