high quality 75-ohm BNC cables from C2G are ideal for video applications including CCTV, broadcast, studio, boardroom presentation, home cinema, etc. Manufactured from coax cable and nickel plated BNC connectors. A molded PVC strain relief protects the cable from wear over time.
Product Description | C2G video cable - 50 cm | Cable | Video cable | Technology | Double shielded coaxial | American Wire Gauge (AWG) | 22 | Length | 50 cm | Connector | BNC - male | Connector (Second End) | BNC - male | Compliant Standards | RG-59 | Features | Moulded |
General | |
Cable Type | Video cable |
Jacket Material | PVC |
Shielding Material | Foil with copper braid |
Impedance | 75 Ohm |
Length | 50 cm |
Plated Connector | Nickel |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
