With a C2G Enhanced CAT5 350MHz Crossover Patch Cable and a network adapter, you can easily network two Windows-based computers in a peer-to-peer networking configuration. In addition, this cable can be used for hub-to-hub, transceiver-to-transceiver or repeater-to-repeater Ethernet connections.
Product Description | C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 50 cm - red | Type | Crossover cable - CAT 5e | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568B | Wires per Cable | 8 wires | Features | Stranded, uniboot | Length | 50 cm | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Red |
General | |
Network Cable Type | Crossover cable - CAT 5e |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 50 cm |
Colour | Red |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS - up to 350 MHz |
