For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
Product Description | C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 1.5 m - yellow | Type | Patch cable - CAT 6 | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568B | Features | Molded, snagless, stranded | Length | 1.5 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Yellow |
General | |
Network Cable Type | Patch cable - CAT 6 |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Plated Connector | Gold |
Length | 1.5 m |
Colour | Yellow |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS - up to 550 MHz |
