The TruLink USB 2.0 Active Extension Cable is perfect when you need extra distance; this cable will extend the reach of your USB 2.0 cable or device 12m (40'). The USB active extension cable actively buffers the incoming and outgoing signals to ensure compliance with the USB 2.0 specification for electrical and timing minimums. Both low and high speed USB devices will function equally well with this cable. Great for extending the reach to your USB devices.
Product Description | C2G TruLink USB 2.0 Active Extension Cable - USB extension cable - USB to USB - 12 m | Type | USB extension cable | Features | Active cable (signal regeneration) | Length | 12 m | Connector | 4 pin USB Type A - female | Connector (Second End) | 4 pin USB Type A - male | Compliant Standards | USB / USB 2.0 | Manufacturer Warranty | 1-year warranty |
General | |
Length | 12 m |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, Plug and Play, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | 1-year warranty |
