There is no need for special locking sockets that take up extra space and have a higher cost. Ensure a secure power connection to critical equipment while saving both time and money using this innovative locking connector. Providing power to a server or switch is critical and a secure connection provides peace of mind. When working in a wiring closet or a cabinet space is limited and cords can easily get in the way and accidently be disconnected causing detrimental downtime. Perform maintenance tasks with confidence that the locking power cords will maintain connection without failure.
Cable install or uninstall can be very challenging when little space is available in a cabinet. The locking mechanism could not be simpler to operate. To install the cable plug it in as normal, or to unplug the cable simply grip the connector as normal but place your fingers on the release triggers and pull, the connector will come unplugged just like a normal cable.
Product Description | C2G - power cable - IEC 60320 C19 to IEC 60320 C20 - 4.5 m | Type | Power cable | Features | Lockable connector | Length | 4.5 m | Connector | Power IEC 60320 C19 | Connector (Second End) | Power IEC 60320 C20 | Rated Voltage | AC 250 V | Rated Current | 15 A | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
American Wire Gauge (AWG) | 15 |
Length | 4.5 m |
Colour | Black |
Weight | 1.874 kg |
Connectivity | |
Miscellaneous | |
Compliant Standards | UL, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
