For fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6A TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels with a LSZH outer jacket. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily colour-code your network installation. Each cable is individually labelled with the length for ease of use.
Connector 1: (1) RJ-45 Male.
Connector 2: (1) RJ-45 Male.
Product Description | C2G patch cable - 5 m - grey | Type | Patch cable - CAT 6a | Technology | Unshielded twisted pair (UTP) | Wires per Cable | 8 wires | Features | Booted, snagless, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL), latching clip | Length | 5 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Grey | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 6a |
Jacket Material | Low Smoke Zero Halogen (LSZH) |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 5 m |
Weight | 200 g |
Colour | Grey |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS, TIA/EIA-568-B.2 |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
