We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
LBP6030B
£199.00
2x Toner Bundle
An affordable, space saving mono laser printer designed for personal or small office use. Quiet, reliable and highly energy efficient with low power consumption it delivers fast, high quality prints.
Space saving, mono laser printer
Designed to fit comfortably on the desk, this fast, compact and affordable mono laser printer is perfect for personal and small office use. Its sleek, space-saving design in a stylish black colour includes a retractable paper tray cover and keeps dimensions to a mere 364 x 249 x 198 mm (W x D x H).
Fast, productive performance
The i-SENSYS LBP6030B springs into the action the moment you need it thanks to Canon’s Quick First-Print technologies, which ensure quick recovery from sleep mode. With a First Print Out Time (FPOT) of just 7.8 seconds and professional laser print speeds of 18 ppm there’s no waiting around for your prints – so you can quickly get back to what’s important.
Product Description | Canon i-SENSYS LBP6030B - printer - B/W - laser | Printer Type | Personal printer - laser - B/W | Weight | 5 kg | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76.2 mm x 188 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 18 ppm - B/W - A4 (210 x 297 mm) | Max Resolution (B&W) | 2400 x 600 dpi | Image Enhancement Technology | Automatic Image Refinement | Interface | USB 2.0 | RAM Installed (Max) | 32 MB | Language Simulation | Canon Ultra Fast Rendering (UFRII LT) | Media Type | Envelopes, transparencies, labels, plain paper, heavy paper | Total Media Capacity | 150 sheets | Media Handling | 150-sheet multipurpose tray | Monthly Duty Cycle (max) | 5000 pages | Power | AC 220-240 V | System Requirements | Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition | Dimensions (WxDxH) | 36.4 cm x 24.9 cm x 19.9 cm |
General | |
Printer Type | Personal printer - laser - monochrome |
Printer | |
Connectivity Technology | Wired |
First Print Out Time B/W | 7.8 sec |
RAM | |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 188 mm |
Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm) |
Media Weight | 60 g/m² - 163 g/m² |
Media Feeders | 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² |
Output Trays Capacity | 100 sheets |
Duty Cycle | |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B |
Miscellaneous | |
Consumables Included | 2 x toner cartridge (black) - up to 1600 pages ISO/IEC 19752 - Canon 725 |
Power | |
Power Device | Power supply - internal |
Voltage Required | AC 220-240 V |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 870 Watt |
Power Consumption Stand by | 1.8 Watt |
Power Consumption Sleep | 0.8 Watt |
Software / System Requirements | |
OS Required | Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition |
Environmental Standards | |
ENERGY STAR | Yes |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
Sound Emission (Operating) | 49.2 dBA |
Dimensions & Weight | |
Width | 36.4 cm |
Depth | 24.9 cm |
Height | 19.9 cm |
Weight | 5 kg |
