HP LaserJet MFP M234sdw Multifunction Printer
FREE DELIVERY
£271.99
Delivery:
Notify me
Key features
  • Speed through multipage documents with the fastest in-class two-sided printing speed.
  • Get high-quality scanning. Share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere – with HP Smart app.
  • Get started fast with easy setup that guides you, step by step. Simply download the HP Smart app, connect to a network, and share your printer across all your devices.
  • This HP LaserJet meets Eco Label requirements, including ENERGY STAR and BLUE ANGEL.
  • Type: Printer / copier / scanner
  • Functionality: Scanner, Copier, Printer
  • Max Paper Size: 216 x 356 mm
Product codes
A high-productivity MFP with the fastest two-sided printing in its class, an automatic feeder, and the time-saving HP Smart app. Count on peace of mind from more reliable connections, and a worry-free experience with simplified setup.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Product Description HP LaserJet MFP M234sdw - multifunction printer - B/W
Device Type Multifunction printer
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 20000 pages
Recommended Monthly Volume 200 - 2000 pages
Max Copying Speed Up to 29 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 29 ppm
Max Printing Resolution Up to 600 x 600 dpi
Scanning 600 x 600 dpi
Display 1.6"
Original Size Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 40 sheets
Media Size 101.6 x 152.4 mm (min) - 216 x 356 mm (max)
Media Type Envelopes, plain paper, bond paper
Standard Media Capacity 150 sheets
Max Media Capacity 150 sheets
Output Trays Capacity 100 sheets
Automatic Duplexing Yes (copying) Yes (printing)
Connection Availability Yes
Interface USB 2.0, LAN, Wi-Fi(n), Bluetooth LE
AirPrint Enabled Yes
Office Machine Features Scan to e-mail, Mopria certified, anti-dust cover, scan to PC, HP Auto-On/Auto-Off Technology, IPP printing, print from mobile devices, scan to PDF
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 41.8 cm x 30.8 cm x 29.44 cm
Weight 9.5 kg
Environmental Standards EPEAT Silver, ENERGY STAR Qualified, Blue Angel
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£271.99
Notify me
