The DCS-960L HD 180° Panoramic Camera is a revolutionary camera offering a horizon-wide view that easily captures your entire room, wall-to-wall, in high-quality 720p.
Product Description | D-Link DCS 960L HD 180-Degree Wi-Fi Camera - network surveillance camera | Device Type | Network surveillance camera - fixed | Audio | Yes: built-in microphone | Dimensions (WxDxH) | 9.6 cm x 9.6 cm x 13.8 cm | Weight | 141 g | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Max Resolution | 1280 x 720 | Frame Rate (max) | 30 frames per second | Motion Detection | Yes | Video Modes | 720p | Optical Sensor Type | CMOS - 1/2.7" - 1 MP | Minimum Illumination | 0 lux - IR | Focal Length Control | Fixed focal | Focal Length | 1.72 mm | Lens Iris | F/2.0 | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Voltage | DC 5 V | Features | Date/time stamp, sharpness control, progressive scanning, resizing an image, saturation control, brightness control, contrast control, USB powered, Motion Detection Technology, light sensor, infrared cut filter, Sound Detection Sensor, hue control, Wi-Fi Protected Setup (WPS), reset button, Text Caption Overlay, password protection | Environmental Parameters (operating) | 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in microphone |
Width | 9.6 cm |
Depth | 9.6 cm |
Height | 13.8 cm |
Weight | 141 g |
Camera | |
Type | Colour - Day&Night - fixed |
Digital Video Format | MJPEG, H.264 |
Max Digital Video Resolution | 1280 x 720 |
Digital Zoom | 8 |
Infrared LEDs | 2 |
Infrared Distance | 4.88 m |
Video Capture | 1280 x 720 @ 30 fps , 800 x 600 @ 30 fps , 720 x 480 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps |
Supported Image Formats | JPEG |
Image Sensor | |
Type | 1 MP CMOS 1/2.7" |
Lens Construction | |
Type | Fixed focal |
Lens Iris | F/2.0 |
Horizontal Field of View (degree) | 180 |
Vertical Field of View (degree) | 120 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac |
Network Protocols | DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, Bonjour, RTCP, PPPoE |
Expansion / Connectivity | |
Ports | USB (power only) - Micro-USB Type B |
Supported Memory Cards | microSD Card, microSDHC Card |
Miscellaneous | |
Compliant Standards | FCC Class B certified, ICES, LVD |
Power | |
Power Requirements | DC 5 V - 1.2 A |
Power Device | Power adapter - external (50/60 Hz) |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Relative Humidity (operating) | 20 - 80% (non-condensing) |
