Introducing the EZVIZ Video Doorbell with PIR
EZVIZ’s Video Doorbell has a 3MP Resolution camera and Weatherproof casing for Outdoor use. It’s 180-degree vertical viewing angle and 105-degree horizontal view, lets you see who’s there from head to toe and even talk to them when you are not home. Connect it to your smartphone via the EZVIZ app to keep your home safe. It also comes with 3 different angle plates and 3 different colour facia plates for optimum look and view. Professional Installation Recommended, available via ezvizlife.com/uk
Answer the door from anywhere
The Doorbell initiates a video call via the EZVIZ App when someone rings your doorbell, so you’ll never miss a visitor. See and talk to your visitors from your smartphone anywhere, any time. The built-in microphone and speaker make it easy for you to hear what’s happening outside the door.
Be Informed
Featuring PIR technology to help reduce false triggers, it simply detects heat sources only, such as Cars, Animals and Humans near or approaching your door. Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Amazon Alexa & Google Home Compatible
Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
Secure Your Home Day & Night
The lens is circled by IR LEDs for clear video even when it’s dark, giving clear night vision and recording, providing 24/7 security in your home or office.
Two-way Talk
The internal microphone supports audio pickup within five meters and video recording with sound, meaning you can have a two-way conversation if needed via the EZVIZ app.
Easy Setup
For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 128GB) for local storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
Works with EZVIZ Alarm Systems
Link to a specific EZVIZ alarm sensor via the app to ensure footage begins straight away when a sensor is triggered. Furthermore, one set via the app, the Pan/Tilt feature will automatically move direction towards the sensor in question helping capture the whole event from all angles.
What’s in the box
Product Description | EZVIZ DB1 - IP intercom station - Wi-Fi | Product Type | IP intercom station | Functions | Motion detection, camera | Integrated Components | Microphone, speaker | Power Source | Hardwired | Connectivity | Wireless - Wi-Fi | Frequency Band | 2.4 Ghz, 5 GHz | Camera | 1/2.8" - Max Resolution 2048 x 1536 - audio - Day&Night | Dimensions (WxDxH) | 4.6 cm x 2.1 cm x 13 cm |
General | |
Connectivity Technology | Wireless |
Features | Waterproof, 2-way audio, microSD Memory Card slot |
Camera | |
Image Sensor | 1/2.8" |
Lens Aperture | F/2.4 |
Focal Length | 2.2 mm |
Day & Night Functionality | Yes |
Audio Support | Yes |
Max Digital Video Resolution | 2048 x 1536 |
Features | Backlight Compensation (BLC), weatherproof, Digital Wide Dynamic Range (D-WDR), 2-way voice communication, 3D digital noise reduction (DNR), 180° field of view (horizontal), 105° field of view (vertical) |
Motion Sensor | |
Detection Mode | Passive infrared (PIR) |
Miscellaneous | |
Nominal Voltage | AC 8 - 24 V |
Power Consumption Operational | 5 Watt |
Compliant Standards | IP65 |
Dimensions & Weight | |
Width | 4.6 cm |
Depth | 2.1 cm |
Height | 13 cm |
Weight | 125 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 25 cm |
Shipping Depth | 19.2 cm |
Shipping Height | 7.55 cm |
Environmental Parameters | |
Min Operating Temperature | -30 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 0 - 95% (non-condensing) |
