Count on performance. Print professional-quality, two-sided color documents - letter and A4 - with outstanding reliability. Efficient one-touch printing and mobile printing options plus simple management help you be productive wherever work takes you.
Product Description | HP Color LaserJet Managed M651xhm - printer - colour - laser | Printer Type | Workgroup printer - laser - colour | Weight | 39.1 kg | Localisation | English, German, French, Italian, Spanish / Europe | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 42 ppm - B/W - A4 (210 x 297 mm) , Up to 42 ppm - colour - A4 (210 x 297 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 38 ipm - colour duplex - A4 (210 x 297 mm) | Max Resolution (B&W) | 1200 x 1200 dpi | Max Resolution (Colour) | 1200 x 1200 dpi | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, USB 2.0 host | AirPrint Enabled | Yes | Preview Screen Size | 4.3" | Processor | 800 MHz | RAM Installed (Max) | 1.5 GB (1.5 GB) | Language Simulation | PCL 5C, PostScript 3, PCL 6, PDF, URF | Media Type | Envelopes, transparencies, greeting cards, labels, plain paper, heavy-weight glossy paper, bond paper, recycled paper, opaque film, card stock, extra heavy-weight paper, light-weight paper, super glossy photo paper, preprinted paper, glossy paper | Total Media Capacity | 3100 sheets | Media Handling | 100-sheet multipurpose tray, 1500-sheet high-capacity feeder, 3x 500-sheet input trays | Monthly Duty Cycle (max) | 180000 pages | Recommended Monthly Volume | 2000 - 30000 pages | Networking | Print server | Printer Features | Hardware integration pocket, Hard Disk Drive Encryption, print from mobile device | Power | AC 120 V | System Requirements | Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Microsoft Windows Server 2003 SP2 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X Lion 10.7, Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows Server 2008 R2 (64-bits), Apple MacOS X 10.9, Microsoft Windows Server 2012 (64-bit) | Dimensions (WxDxH) | 55 cm x 52 cm x 45.5 cm |
General | |
Printer | |
Built-in Devices | Touch screen |
Connectivity Technology | Wired |
PostScript Support | Included |
First Print Out Time B/W | 9 sec |
First Print Out Time Colour | 9 sec |
Fonts Included | 105 x TrueType , 92 x PostScript 3 |
Processor | |
RAM | |
RAM Installed (Max) | 1.5 GB / 1.5 GB (max) |
Media Handling | |
Media Sizes | Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), 100 x 150 mm, 76 x 127 mm |
Media Weight | 60 g/m² - 220 g/m² |
Media Feeders | 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 3 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 1500 sheets - Legal (216 x 356 mm) |
Max Media Capacity | 3100 sheets |
Duty Cycle | |
Networking | |
Network Controller Name | HP Jetdirect |
Remote Management Protocol | SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDPS, NDS, HTTPS, TFTP, IPPS, SLP |
Security Protocols & Features | Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Included Accessories | Stand |
Consumables Included | 1 x toner cartridge (black) - up to 11500 pages , 1 x toner cartridge (cyan) - up to 15000 pages , 1 x toner cartridge (magenta) - up to 15000 pages , 1 x toner cartridge (yellow) - up to 15000 pages |
Features | Security lock slot (cable lock sold separately), USB port control |
Compliant Standards | ICES-003, FCC CFR47, Directive 2004/108/EC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55022:2010 Class A, CISPR 22:2008, EN55024:2010 |
TAA Compliant | Yes |
Security Slot Type | Kensington security slot |
Power | |
Power Device | Power supply - internal |
Voltage Required | AC 120 V |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 650 Watt |
Power Consumption Stand by | 67 Watt |
Power Consumption Sleep | 8.5 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Microsoft Windows Server 2003 SP2 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X Lion 10.7, Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows Server 2008 R2 (64-bits), Apple MacOS X 10.9, Microsoft Windows Server 2012 (64-bit) |
System Requirements Details | Windows XP/Vista/7/8/2003/2008/2012 - HD 200 MB , MacOS X 10.6/10.7/10.8/10.9 - HD 1 GB |
Environmental Standards | |
Blue Angel | Yes |
ENERGY STAR | Yes |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 30 - 70% |
Dimensions & Weight | |
Width | 55 cm |
Depth | 52 cm |
Height | 45.5 cm |
Weight | 39.1 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 75 cm |
Depth (Shipping) | 67.8 cm |
Height (Shipping) | 59.7 cm |
Weight (Shipping) | 44.6 kg |
