Get professional-quality colour that's ready for business. Easily print up to 27,9 x 43,18 cm (11 x 17 inches) (A3), at up to 50% less cost-per-page than laser, and handle high-volume printing needs.
Product Description | HP Officejet Pro 7730 Wide Format All-in-One - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Plain paper | Localisation | EMEA (excluding Israel, Saudi Arabia, South Africa) | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Recommended Monthly Volume | 250 - 1500 pages | Max Copying Speed | Up to 18 ppm (mono) / up to 13 ppm (colour) | Max Copying Resolution | Up to 600 dpi (mono) / up to 600 dpi (colour) | Max Printing Speed | Up to 18 ppm 34 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi | Scanning | 1200 dpi | Display | 2.65" | Original Size | 216 x 356 mm (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | 297 x 431.8 mm (max) | Media Type | Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper | Standard Media Capacity | 250 sheets | Output Trays Capacity | 75 sheets | Automatic Duplexing | Yes (printing) | Connection Availability | Yes | Interface | USB 2.0, LAN, Wi-Fi(n), USB host | AirPrint Enabled | Yes | Office Machine Features | Scan to PC | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 58.49 cm x 44.48 cm x 38.58 cm | Weight | 18.5 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Ink-jet - colour |
Display Diagonal Size | 2.65" |
Display Colour Support | Colour |
Display Features | Touch screen |
Memory | |
Standard Memory | 512 MB |
Max Supported Memory | 512 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Copying Features | ID Card Copy, quality adjustment |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Nozzle Configuration | 1568 nozzles (black), 6272 nozzles (colour) |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 3 GUI |
Automatic Duplexing | Yes |
First Print Out Time B/W | 9 sec |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Fax Machine | |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 100 pages |
PC Faxing | Yes |
Fax Machine Features | |
Speed Dialing | 99 station(s) |
Broadcast Transmission | Yes |
Delayed Transmission | Yes |
Features | Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD) |
Document & Media Handling | |
Max Original Size | 216 x 356 mm |
Max Media Size | A3 |
Min Media Weight | 60 g/m² |
Max Media Weight | 105 g/m² |
Supported Media Type | Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm) |
Document & Media Handling Details | ADF - 35 sheets size: 76 x 127 mm - 216 x 356 mm , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets |
Speed Details | Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 18 ppm - B/W (ISO) , Printing: up to 22 ppm (A4) - B/W normal , Printing: up to 34 ppm (A4) - colour draft , Copying: up to 13 ppm (A4) - colour (ISO) , Copying: up to 18 ppm (A4) - B/W (ISO) , Copying: up to 34 ppm (A4) - B/W draft , Copying: up to 34 ppm (A4) - colour draft |
Connections | |
Interfaces | 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x modem - RJ-11 |
Security Protocols & Features | Apple Bonjour, WEP, WPA, AES |
Operating System Support | Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition |
Software Included | HP Photo Creations, HP Update, Google Toolbar, Software HP Printer |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 29.4 Watt |
Power Consumption Standby | 6.02 Watt |
Power Consumption Sleep | 1.42 Watt |
Miscellaneous | |
Compliant Standards | BSMI, GS, CCC, FCC CFR47 Part 68, UL 60950-1 Second Edition, FCC CFR47 Part 15 B, IPv6 Ready, EAC, IEC 60950-1:2005 Second Edition, EN 61000-3-3:2013, EN 55024:2010, EN 61000-3-2:2014, R&TTE Directive 1999/5/EC, GB 4943.1-2011, EN 55032:2012, TIA-968-B, ICES-003 issue 6, ICES-003 issue 6 Class B, CISPR 32:2012 Class A, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - web support - 1 year , Technical support - phone consulting - 1 year |
Dimensions & Weight | |
Width | 58.49 cm |
Depth | 44.48 cm |
Height | 38.58 cm |
Weight | 18.5 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 67.7 cm |
Shipping Depth | 49.5 cm |
Shipping Height | 48.7 cm |
Shipping Weight | 23.13 kg |
Environmental Parameters | |
Sound Emission | 61 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 8 - 85% |
