Designed exclusively for ultraslim HP EliteBook Notebook PCs, the HP UltraSlim Docking Station expands display, network, and device connectivity so you can be more productive throughout the day-all through a simple one-click slide-in side dock.
Product Description | HP UltraSlim Docking Station 2013 - docking station - VGA, 2 x DP | Product Type | Docking station | Video Interfaces | VGA, 2 x DP | Dimensions (WxDxH) | 36.8 cm x 10.7 cm x 4.4 cm | Weight | 760 g | Localisation | English / United Kingdom | Power | Power adapter - external | Manufacturer Warranty | 1-year warranty |
General | |
Width | 36.8 cm |
Depth | 10.7 cm |
Height | 4.4 cm |
Weight | 760 g |
Expansion / Connectivity | |
Interfaces | 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x network - Ethernet - RJ-45 , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x audio - line-In - mini-phone stereo 3.5 mm , 1 x audio - line-out - mini-phone stereo 3.5 mm |
Miscellaneous | |
Features | 2 security lock slots (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Power Device | Power adapter - external |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
