Work away from the desk and still maintain a wireless connection that won't let you, or your customers, down.
Product Description | Jabra Engage - headset - replacement | Product Type | Headset - replacement - DECT - wireless - NFC | Compatibility | Mac, Windows | Recommended Use | Portable electronics, phone, conference | Headphones Form Factor | On-ear | Connectivity Technology | Wireless | Wireless Technology | DECT | Bluetooth Version | Bluetooth 5.0 | Sound Output Mode | Mono | Audio Specifications | Frequency Response 40 - 16000 Hz | Microphone | Boom | Microphone Operation Mode | Uni-directional | Microphones Included | 2 | Controls | Mute, volume, status indicator, answer/end, reject call | Designed For | Engage 65 Mono, 75 Mono |
General | |
Product Type | Headset - DECT - wireless - NFC |
Replacement | Yes |
Width | 14.7 cm |
Depth | 16.9 cm |
Height | 3.2 cm |
Weight | 56 g |
Max Operating Distance | 150 m |
Audio Output | |
Frequency Response | 40 - 16000 Hz |
Simultaneously Connectable Devices Qty | 2 |
Microphone | |
Type | Boom |
Form Factor | Headset microphone |
Frequency Response | 100 - 10000 Hz |
Remote Control | |
Power | |
Battery | Headset battery rechargeable |
Run Time (Up To) | 13 hour(s) |
Standby Time | 52 hours |
Recharge Time | 1.5 hour(s) |
Compatibility Information | |
Designed For | Jabra Engage 65 Mono, 75 Mono |
