The Jabra Link 230 extends the capability of your Jabra corded QD (Quick Disconnect) headset and enhances the audio at the same time. With the plug-and-play USB adapter, you can use your Jabra deskphone headset together with your softphone. The Digital Signal Processing (DSP) technology evens out the audio stream to ensure a clear sound on both ends of the call.
Product Description | Jabra LINK 230 - headset adapter | Cable | Headset adapter | Connector | USB - male | Connector (Second End) | Quick Disconnect | Features | Digital Signal Processing (DSP) technology |
General | |
Cable Type | Headset adapter |
Connectivity | |
Connector | 4 pin USB Type A - male |
Miscellaneous | |
Compliant Standards | Plug and Play, Directive 2003/10/CE |
