Product Description | JBL E65BTNC - headphones with mic | Product Type | Headphones - Bluetooth - wireless - 3.5 mm jack | Recommended Use | Portable electronics | Colour | Matte black | Headphones Form Factor | Full size | Foldable | Yes | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Radio Frequency Range | 2.402 - 2.480GHz | Bluetooth Version | Bluetooth 4.1 | Sound Output Mode | Stereo | Sound Effects | Signature Sound | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 95 dB | Impedance | 32 Ohm | Active Noise Canceling | Yes | Microphone | On-cable | Controls | Remote control | Manufacturer Warranty | 1-year warranty |
General | |
Series | E Series |
Weight | 258 g |
Headband Material | Fabric |
Audio Output | |
Foldable | Yes |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 95 dB |
Max Sound Pressure | 108 dB |
Diaphragm | 40 mm |
Microphone | |
Type | On-cable |
Sensitivity | -42 dB |
Remote Control | |
Wireless Link | |
Modulation Type | GFSK, DQPSK |
Connections | |
Connector Type | Headphones (mini-phone stereo 3.5 mm) |
Miscellaneous | |
Cable Details | Headphones cable - detachable - straight , Micro-USB charge cable - detachable |
Power | |
Battery | Headphone battery rechargeable - Lithium Ion |
Capacity | 610 mAh |
Run Time (Up To) | 24 hour(s) |
Recharge Time | 2 hour(s) |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year |
