The JBL Flip 4 is a portable Bluetooth speaker that delivers surprisingly powerful stereo sound. This compact speaker offers high-quality audio. Sporting durable, waterproof materials, the Flip 4 is the companion that takes the party everywhere.
Product Description | JBL Flip 4 - speaker - for portable use - wireless | Product Type | Speaker - for portable use | Protection | Waterproof | Speaker Type | Active | Continuous Power | 16 Watt | Frequency Response | 70 - 20000 Hz | Amplifier | Integrated | Interfaces | Bluetooth | Intelligent Assistant | Siri, Google Now - indirect | Speaker System Details | 1 x speaker 16 Watt - 70 - 20000 Hz | Speaker Details | Speaker - stereo x 2 - 8 Watt - 70 - 20000 Hz - active | Colour | Black | Battery | Speaker battery rechargeable - Lithium Ion | Dimensions (WxDxH) | 17.5 cm x 7 cm x 6.8 cm | Weight | 515 g |
General | |
Hands-Free Function | Yes |
Enclosure Colour | Black |
Speaker System | |
Signal-To-Noise Ratio | 80 dB |
Interfaces | Bluetooth 4.2 |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Controls | Power on/off, volume |
Internet of Things (IoT) | |
Communications Technology | Bluetooth |
Intelligent Assistant | Siri, Google Now |
Voice Control | Indirect |
Speaker System Details | |
Speakers Included | 1 x speaker - 16 Watt - 70 - 20000 Hz - wireless |
Speaker Details | Speaker - stereo x 2 - 8 Watt - 70 - 20000 Hz CFR - active |
Driver Details | Speaker: 2 x full-range driver , Speaker: 2 x Passive Radiator |
Miscellaneous | |
Included Accessories | USB charging cable |
Compliant Standards | IPX7 |
Battery | |
Type | Rechargeable - Lithium Ion |
Capacity (Ah) | 3000 mAh |
Run Time (Up To) | 12 hour(s) |
Recharge Time | 3.5 hour(s) |
Dimensions & Weight | |
Width | 17.5 cm |
Depth | 7 cm |
Height | 6.8 cm |
Weight | 515 g |
