ITEM | QTY | PRICE |
StarTech.com USB-C Ethernet Adapter w...
4 | £176.28 |
HP Universal Bond Paper-1067 mm x 45....
3 | £70.23 |
Apple Smart Folio Flip cover for tabl...
4 | £286.24 |
Level up with powerful JBL Quantum Duo PC gaming speakers. Go deeper into the action with pitch-perfect sound and unique lighting effects. Easily pinpoint incoming fire, hear enemies creeping up on you and feel the roar of explosive action. With JBL proprietary gaming surround sound and Dolby Digital in a cool, distinctive design. Never miss a step, shot or jump with exposed drivers and tweeters for incredible sound clarity. With the different color presets and lighting patterns to personalize your setup, gaming has never felt more real.
Product Description | JBL Quantum Duo - speakers - for PC - wireless | Product Type | Speakers - for PC | System Components | 2 speakers | Speaker Type | 2-way - active | Nominal Output Power (Total) | 20 Watt | Frequency Response | 60 - 20000 Hz | Amplifier | Integrated | Interfaces | Bluetooth | Colour | Black | Built-in Decoders | Dolby Digital | Dimensions (WxDxH) | 8.9 cm x 17.6 cm x 21 cm | Weight | 2.8 kg | Manufacturer Warranty | 1-year warranty |
General | |
Light | Multicolour LED light |
Enclosure Colour | Black |
Speaker System | |
Audio System Continuous Power (Total) | 20 Watt |
Signal-To-Noise Ratio | 80 dB |
Interfaces | Bluetooth 4.2 |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Controls | Volume |
Speaker System Details | |
Driver Details | Speaker: woofer driver - 2.5" - neodymium , Speaker: tweeter driver - 0.75" |
Connections | |
Connector Type | Audio line-in (mini-phone stereo 3.5 mm) |
Miscellaneous | |
Included Accessories | Audio cable, USB cable |
Power | |
Power Source | Integrated power supply |
Dimensions & Weight | |
Width | 8.9 cm |
Depth | 17.6 cm |
Height | 21 cm |
Weight | 2.8 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
