Here at Juice we only use MFI Approved lightning chips, ensuring every one of our cables works perfectly every time.
The Juice Lightning Cable is a must have for all of your iPhone & iPad charging needs. The Juice MFI Approved Lightning charge and sync cable is compatible with all iPhones & iPads.
Product Description | Juice XL - Lightning cable - 2 m | Cable | Lightning cable | Length | 2 m | Colour | Aqua | Connector | USB - male | Connector (Second End) | Lightning - male | Features | Sync and charge |
General | |
Cable Type | Lightning cable |
Length | 2 m |
Colour | Aqua |
Connectivity | |
Connector | 4 pin USB Type A - male |
Connector (Second End) | Apple Lightning - male |
Miscellaneous | |
Compliant Standards | MFI |
