Juice XL USB Type C charge and sync cable
This improved tech allows you to charge and sync your devices faster via USB-C. Plug the USB connector into a charger or computer and the reversible USB-C connector into your device and charge. Reversible connector allows you to plug in your device in any direction.
3 Amp output - improved technology allows faster data transfer (10 x faster than USB 2. 0).
Device compatibility: All devices with USB-C connection: Mobiles, tablets, gaming devices, laptops, hard drives and more, Samsung compatible mobiles and tablets, Huawei compatible mobiles, One Plus compatible mobiles.
Cable Length: 2m
Product Description | Juice - USB-C cable - USB to USB-C - 2 m | Type | USB-C cable | Features | Sync and charge | Length | 2 m | Connector | 4 pin USB Type A - male | Connector (Second End) | 24 pin USB-C - male | Compliant Standards | USB 3.1 | Colour | White |
General | |
Length | 2 m |
Colour | White |
Weight | 40 g |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB 3.1, RoHS |
