Combining comfort and convenience, the award-winning SmartFit Laptop Riser with Wireless Phone Charging Pad blends 20 years of ergonomic expertise with the latest in reliable wireless charging technology. Lift your laptop up to eye level to relieve neck and back strain, then use the lower platform to wirelessly charge your phone. The SmartFit system allows you to find your personal comfort color and self-fit the riser to your ideal height. It also utilizes Zero Footprint mounting so you can mount any compatible Kensington universal dock underneath the laptop platform, keeping your desktop less cluttered.
Product Description | Kensington SmartFit Laptop Riser with Wireless Phone Charging Pad - notebook stand | Product Type | Notebook stand | Colour | Black | Dimensions (WxDxH) | 17.8 cm x 25.1 cm x 24.3 cm | Weight | 1.18 kg | Notebook Compatibility | 15.6" | Features | Integrated cable management, anti-skid grip, SmartFit, Qi Wireless Charging, kensington security slot, Zero Footprint Mounting | Manufacturer Warranty | 1-year warranty |
General | |
Width | 17.8 cm |
Depth | 25.1 cm |
Height | 24.3 cm |
Weight | 1.18 kg |
Colour | Black |
Miscellaneous | |
Weight Limit | 3.49 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty: - 1 year |
