We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Providing the trusted protection that has made Kensington The Professionals' Choice in laptop security for over 25 years, Kensington's Keyed Cable Lock sets the standard for securing Surface Pro. Providing vigorously tested, non-invasive locking technology that is supported by Kensington's innovative common keying system, the Keyed Cable Lock is the superior security solution for Surface Pro.
Product Description | Kensington Keyed Cable Lock for Surface Pro & Surface Go - security cable lock | Product Type | Security cable lock | Product Material | Carbon steel | Length | 1.8 m | Weight | 270 g | Features | Hidden pin | Manufacturer Warranty | 5-year warranty | Designed For | Microsoft Surface Go, Go 2, Pro (Mid 2017), Pro 4, Pro 6, Pro 7 |
General | |
Length | 1.8 m |
Thickness | 5 mm |
Weight | 270 g |
Security Cable Lock | |
Intended For | Tablet |
Lock Method | Key |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited warranty: - 5 years |
Compatibility Information | |
