Let the leader in professional desktop performance make your transition to USB-C connectivity as smooth as possible with the SD4500 USB-C Universal Dock that works with Windows , Mac OS and Chrome OS devices. A single cable lets you quickly plug in your laptop and have instant access to all your peripheral desktop accessories, including 4K video and data transfer. Zero Footprint mounting is ideal for workstations with limited space (mount sold separately) and its Thunderbolt 3 compatible.
Product Description | Kensington SD4500 USB-C Universal Dual-4K Dock - DisplayPort and HDMI Ports - docking station - USB-C - HDMI - GigE | Product Type | Docking station | Docking Interface | USB-C | Video Interfaces | HDMI | Dimensions (WxDxH) | 23.5 cm x 14.6 cm x 8.59 cm | Networking | Gigabit Ethernet | Power | Power adapter DC 20 V | Manufacturer Warranty | 3-year warranty |
General | |
Width | 23.5 cm |
Depth | 14.6 cm |
Height | 8.59 cm |
Networking | |
Data Link Protocol | Gigabit Ethernet |
Expansion / Connectivity | |
Interfaces | 1 x video - HDMI - 19 pin HDMI Type A , 1 x video - DisplayPort , 2 x Thunderbolt 3 - 24 pin USB-C , 3 x USB 3.1 - 19 pin USB 3.1 header , 1 x audio - line-in/headphones - mini-phone 3.5 mm , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x network - 1000Base-T - RJ-45 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), dual monitor support, 4K Ultra HD |
Security Slot Type | Kensington security slot |
Compliant Standards | Plug and Play |
Power | |
Power Device | Power adapter |
Voltage Required | DC 20 V |
System Requirements | |
OS Required | Google Chrome OS, Apple MacOS X 10.10, Apple MacOS X 10.11, Windows 8.1 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
