Kensington SD4700P Universal USB-C Dock
£162.42
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Plug & Play: DisplayLink driver installation required
  • Maximum resolution supported: Single monitor - 2560 x 1600 @ 60Hz and Dual monitors - 2048 x 1152 @ 30Hz
  • No of monitors supported: 2
Product codes
Supporting the advanced USB-C connections, and legacy computers with USB 3.0 ports, the SD4700P Universal USB-C and USB 3.0 Docking Station is the ideal docking solution for evolving computer environments. Engineered using stable technology, the SD4700P provides compatibility that just works. The SD4700P extends the life of your technology investments and is easy and painless to setup.
Kensington SD4700P Universal USB-C Dock - docking station - HDMI, DP
Docking station
Docking Interface
USB-C / USB 3.0
Video Interfaces
HDMI, DP
20 cm x 9.12 cm x 3.05 cm
1.13 kg
Europe
Gigabit Ethernet
Power adapter 135 Watt AC 120/230 V / DC 20 V (50/60 Hz)
Pricing Type
Brown Box
3-year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SD4700P Uni...
£162.42
